Lookout
ERO Temperature Controllers
Has anyone had experience of communicating with ERO Temperature Controllers?
The newer versions have a Modbus protocol, but we are using older ones with
only ERO protocol.
John Dunlop
(5,962 Views)
Depending on how easy the "ERO" protocol is, and how complex your communication
is going to be, you may be able to use the ASCII Object in Lookout. As you
are aware, ASCII Object is ideal for sending and receiving simple ASCII characters.
If you think this is feasible I can give you an example which shows how
to use an ASCII Object as a simple serial driver.
The other (better) option is for you to write your own driver using Lookout's
Object Developer Toolkit. You have to be fluent with C/C++ and the VC++
development environment.
Any other ideas?
Khalid
"John Dunlop" wrote:
>>Hi,>>Has anyone had experience of communicating with ERO Temperature Controllers?>
using older ones with>only
ERO protocol.>>Thanks,>>John Dunlop
(5,962 Views)
