Lookout
EXIT function
Is there a method of exiting lookout from within an application? If I hide
the menu bar the file/exit menu selection is not availible. Writing a Visual
Basic program to do an API call to ExitWindowsEx only seems to work correctly
if you have administrator rights.
(4,094 Views)
Starting from Lookout 4.5:
create a run object and put following as the command line: "lookout.exe -shutdown" (including the quotes). This works no matter if file needs to be saved or if you are or are not administrator.
(4,094 Views)
This solution solved my problem of being able to have a user exit out of lookout while having a low security level. I was not able to do this even if I set the "User cannot exit lookout" value to a low number. The option to Exit was available, but no action was taken when clicked. I'm glad Martin posted this so I wouldn't have to bother him with yet another question!
(4,094 Views)
