Lookout
Enhanced Modbus TCP driver for Lookout ?
I am trying to use Lookouts Modbus TCP driver to talk to my Modbus RTU slaves through a Lantronix transparent gateway. I have four slaves on the RTU side, 1,2,3,4 but there doesn't seem to be a way to embed the NodeID in the standard Lookout Modbus TCP driver configuration. Does anyone know if this is supported and/or how I alter my settings to allow this? Modbus TCP specification has a field for NodeID, as well as the IP address, but when analysing the output from Lookout this always seems to be a zero (broadcast ID).
(3,429 Views)
What version of Lookout are you using? In the latest versions (4.0 and beyond?) there's this Identifier option in addition to the IP Address.
Khalid
(3,429 Views)
Hi Khalid,
Thanks a lot for this - we were using ver 4.00 which doesn't have the Identifier tab. Looking at 4.50 and onwards it now appears, which solves my problem.
Dan
(3,429 Views)
