Lookout
Error: bad quality (3):processing read data(50): unknown reason (00000000)
I am using Lookout 4.0.1b51 and OPC server (Eurotherm). Error occurs every 30 mins!! Restarting lookout helps for a further 30 mins. Viewing the OPC server, I can see the data, no problem. All values are numeric.
(3,368 Views)
I see this alarm message if the OPC server gets overloaded and can't completely respond (not a full commfail - a partial if you will) but the alarm soon clears. I am not familiar with the Eurotherm, could you post more info on the configuration of the Lookout OPC client object? Also, have you tried connecting a pushbutton to the PollDevice data member to force a poll?
(3,368 Views)
The client is a single panel with 5 guages and a hypertrend. The HT contains the same 5 inputs. The inputs are all 32 bit registers from the OPC server. It cannot be simplier!! The error can be acknowledged but does not go away till Lookout is rebooted.
(3,368 Views)
