Lookout
Error message in Lookout
Hi, we have a version 6.7 of lookout and are trying to migrate our data from an older version of lookout (6.0). We are getting an error message. I have attached to this post. If anyone has any idea how to resolve, i could use the help. Also need to know what other files i need to copy over from the older version of lookout to the new system to make sure the migration works fine.lookout error1.jpg
(4,771 Views)
On the open dialog, change the file type to Lookout Source file (LKS) and open the LKS to recompile.
Forshock - Consult.Develop.Solve.
(4,764 Views)
Thank you so much. That seemed to work. Is there any other files that i need to copy over so that our config is the same?
(4,754 Views)
Depending on how it is developed there may be others.
Graphics folder, database, DataTable/Excel files, etc.
Run it and find out 😉
(4,743 Views)
Seems to run fine. Another issue I noticed is when I open the file, it compiles, but I can't save the compiled file. The options are grayed out. I am logged in as admin in lookout and pc. Any ideas?
(4,736 Views)
You may be running a Runtime version or the IO count is exceeded.
(4,636 Views)
