Lookout
Excel report on a daily basis
I must create a Excel report on a daily basis.
Can someone maybe comment on my design/approach listed below?
1)Create a SQLExec that connects to the Citadel ODBC Database
2)Create a DataTable object to link to a xls file
3)Do queries on the SQLExec and some calculations
4)Write the results to the xls file
5)Activate some macros on the xls file from Lookout
(3,000 Views)
I found an example that does most of this: Querying Citadel Database and Exporting Data to Excel
. See also Citadel ODBC Queries using Lookout SQLexec.
For the last step, write the macros that you need in Excel so that they run according to the value of a "command" cell. Then use Lookout to change the value of that cell to run the respective macro.
(3,000 Views)
