Lookout
Expression does not display on start up
I am using some expressions to display some text strings to show switch status.  The  expression string is  "tif(Modbus2.01234,"ON DISPLAY MESSAGE","  ")".    When I start Lookout 6.0.1, the expression string works correctly on some places on the screen.  In other places, the string does not display or work correctly.  If I modify the string by adding a space or letter to the message, the string will work correctly.  I save the application, close it out, and restart it and the same message string does not work correctly until modified.  I also have this problem with a numeric display.  I have to modify the address to get it to start to display.
Any suggestions?
Message 1 of 1
(3,159 Views)
