Lookout
Getting message "Bad quality received from network module". Then FP1600 no longer communicates, cant ping it. When
it is power cycled it works again. We have another FP1600 on same network with no problem. Ethernet drop is 230 feet. Part# is 185690E-01, firmware 4.11. I have swapped it with a spare unit we have of the same part number, 185690E-01 and firmware release.The FP1600 has been swapped with a spare we have, the network cable has been replaced, the FP-TC-120 has been swapped with a spare. The IP address has been changed.
(3,449 Views)
it is power cycled it works again. We have another FP1600 on same network with no problem. Ethernet drop is 230 feet. Part# is 185690E-01, firmware 4.11. I have swapped it with a spare unit we have of the same part number, 185690E-01 and firmware release.Mike,
Thank you for using the discussion forums. If possible, please generate a phone support request at ni.com/ask. One of our engineers will be happy to help you resolve this particular issue.
Michael Shasteen
Applications Engineering
www.ni.com/ask
1-866-ASK-MY-NI
(3,449 Views)
it is power cycled it works again. We have another FP1600 on same network with no problem. Ethernet drop is 230 feet. Part# is 185690E-01, firmware 4.11. I have swapped it with a spare unit we have of the same part number, 185690E-01 and firmware release.I thought the whole point of using this forum is that users would not have to get on the phone to get answeres to technical questions. I have the same problem as the user that you answered. Please post the solution to this issue on the discussion forum.
Jonathan
(3,449 Views)
it is power cycled it works again. We have another FP1600 on same network with no problem. Ethernet drop is 230 feet. Part# is 185690E-01, firmware 4.11. I have swapped it with a spare unit we have of the same part number, 185690E-01 and firmware release.NI told me the E version of the FP-1600 has this known problem. They swapped it with a FP-1601 and the problem went away. I also had a B version of the FP-1600 and put it in the same location as the E version I was having problems with and it never failed, only the 2 Es I had.
(3,449 Views)
