Lookout
Graphics not found
I updated some graphics on an existing Lookout 6.5 application. The custom graphics that were created for some valves wouldn't show up on my developmment system but did on the original target PC. Since then, the target PC crashed and whenwe load the application folders on to it the custom graphics aren't found there either. When I open the properties it says the wmf files defined cannot be found. However, when I look in the graphics folder directly the files do exist. It seems that the path tp the graphics may need to be altered? How do I do that?
(4,587 Views)
The simplest way is to right click each object, select object properties then left click the graphics (which will be blank or showing a text message or whatever) then navigate in the left side of the pop-up window to the location of the graphic file and add the graphic. Click OK. Bit long winded but it will work. Bill
(4,512 Views)
