Lookout
Has anyone used Lookout 4.5 with Motorola MOSCAD?
If so, please send me an e-mail at oscheurer@aegis-solutions.com. My question is, Can I use the ModbusMOSCAD driver to talk directly to a RTU in the field via radio without using a FIU or do I have to use and FIU and talk modbus to the FIU and let the FIU gather the info from the field?
(3,576 Views)
Here's what the Lookout online help says:
The ModbusMOSCAD object class works with Motorola MOSCAD PLCs and RTUs. It also uses the Modbus Serial (ASCII or RTU) or Modbus Plus communication protocol, but its data members reflect the address of Motorola MOSCAD devices.
It looks like you should be fine using the modbusMOSCAD object in Lookout
(3,576 Views)
