Lookout
Having problems with XCHART after reset
I'm using XCHART to record statistical info.  When I activate "reset", the average (XCHRT.CL) and std dev ((XCHR.UCL-XCHRT.CL)/3) go to zero but do not begin updating again even though the trigger is active.  When I open the XCHART object from edit mode and close it, it starts updating again even though I haven't changed anything.
(3,669 Views)
CSMP,
Is the trigger input actually seeing an edge? Where are you getting your trigger signal from? If it is just staying high, then the XCHART won't update.  The XCHART only updates when the trigger goes from low to high.
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(3,656 Views)
Thanks for the response!  I will modify the code to let me "reset" on the fly.
(3,649 Views)
