Lookout
How can I do a hex AND operation in Lookout?
Hi All,
I am trying to AND two hex numbers together in Lookout and remember there used to be a /x format or something like it that used a hex notation. Any clues???
John
Bytronic Automation Ltd
U.K.
(3,256 Views)
If you have Lookout version >=4 then it is not too hard since Lookout supports data polymorphism. Attached is a Lookout 5.0 file that can help you. If you do not have Lookout 5 then compile the script file (.lks) in Lookout 4 (you may need to make some minor modifications). If you have < Lookout 4 then this may not work at all.
Basically, I parsed the hex value into its binary components and performed individual bit ands. I then recombined the bits to output a decimal and hexadecimal value. Its a little tedious but not too hard.
This will at least give you some ideas.
Tommy Scharmann
(3,256 Views)
