Lookout
How can I include a carriage return in a expression
How can I include a carriage return in a expression between text strings eg
Expression 1 = Text1 & text2 & text3 & text4
I need to display it as below
Text1
Text2
Text3
Text4
adjusting the box the size doesn’t work as the text strings are variable lengths
(4,463 Views)
If you want to send such string by Ascii object, use \r.
See "ASCII Object Format Markers" in Lookout help.
Ryan Shi
(4,450 Views)
I could not get it to work I keep on getting an error
I want to use a carriage return in a normal expression to display variable length text strings, I am not using it with the ASCII object
thanks
Ian
(4,439 Views)
Message Edited by Ryan.S on 01-04-2007 08:17 PM
Ryan Shi
(4,427 Views)
You can input the text with carriage return, as the attachment shows.
Ryan Shi
(4,424 Views)
