Lookout
How can I insert gif animation into my Lookout process.Currently I'm using Lookout ver.5 on my Win98 se.Thanks
I have to use animation instead using animator object so that my process look attractive.Thanks.
(3,058 Views)
Here is one fairly quick and easy way that should work with Win98. Create a new object, but not a Lookout object. Click on the activeX tab and look in the Recommended folder. There you should find Microsoft Web Browser. Select this as your new object to create. Change the name if you want, but leave everything else blank. Now from Windows Explorer simply drag the GIF file and drop it in the object display. The animation should begin doing whatever it does right away.
(3,058 Views)
