Lookout
How can I set up two control panels in two seperate monitors using Lookout version 4?
I have Lookout version 4, and dual monitors and i am trying to make it so two seperate control displays come up at the same time upon opening in the different monitors.  The guy at tech support said it is not possible, so Iwas wondering if anybody has a possible creative solution to this problem?
(4,164 Views)
Run two instances of Lookout (not possible in LO6+)
You would need to manual put each process on each display
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(4,162 Views)
