Lookout
How do I alert a cell phone of an alarm?
I am running Lookout 5.0 and want to alert a cell phone when an alarm occurs. I especially want to give the phone answerer a voice message of the alarm. Anyone done this?
(5,348 Views)
You will need to use a thrid party software package called Win911. You can get all the info at http://www.specterinstruments.com/
(5,348 Views)
Fer crist sakes no. You can do this with a data member and pager object. We have one application currently running in this fashion.
(5,348 Views)
Any other info or details you can give me to steer me in the right direction would be appreciated. In your application, are you able to give a voice message with the phone call?
(5,348 Views)
You can use num12358 application to steer numeric messages to a cellphone, but not voice. Again you will need to use a third party software that I spoke of orginally.
(5,349 Views)
On an old project we were able to send a text message to a pager predicated on the alarm. Now, if memory serves me well, we had to use a mailer object that sent an e mail inturn accessed a pager. With that said, you should be able to use a pager object with a variable text message using type alphanumeric. Getting the cell phone to display alphanumeric has been more trouble than the rest. Now, can you play a .wav file instead of using text? I have not yet tried.
(5,348 Views)
If you do not have the option of using 3rd-party software, you can may be use the Pager object to send the text message, and then the ASCII object to call the cell phone repeatedly for, say, 3 times. This way, the user hears the rings (which may not be the case when a text msg is received) and would know to check the txt message. Just a thought.
Khalid
(5,174 Views)
