Lookout
How do I install client license with Lookout Developer license?
I have Lookout developer license running on my system and wish to keep it as the main software. I purchased the Lookout Enterprise runtime license with four clients. I wish to use the clients from it with the developer license. How do I do this?
(3,400 Views)
You should have gotten a single serial # and 2 key codes with your new package. One for the runtime and another for the clients. The same serial # is used for both. All you have to do is go to Options >> System >> Change Client License >> Add. Then just type in your organization, serial # and keycode for your clients. The fact that you have the development license should not make a difference. You can inter-mix different serial #s between registration info and client info.
(3,400 Views)
Great answer Carl. Also to clarify you can not install different Lookout packages on the same machine.
Robert Jackson
Application Engineer
(3,400 Views)
Carl,
Thank you for the answer. I was trying to install the client from the new software package and it does not allow you to install multiple Lookout packages on the same computer. I registered the software and used the key as suggested and it did work.
Thank you!
(3,400 Views)
