Lookout
How do I interface Lookout with Visual Basic?
I've been doing some research and I think the best way to do it would be to utilize the OPC server.  However, I really don't have a good idea of how to do that.  Is there a dll that I need to call and set up to interface with it?  Do I need to set up an OPC server from the VB side?  Any direction would be nice.  Thanks!
Message 1 of 11
(9,240 Views)
So, in VB, use datasocket to connect the Lookout OPC Server to read/write tags in Lookout.
Or, you can directly use datasocket to do communicate between Lookout and VB. Lookout does support datasocket.
Maybe DDE is another option. not sure.
Ryan Shi
Message 2 of 11
(9,227 Views)
I think a light just went on in my head...  Smiley Happy
Message 3 of 11
(9,219 Views)
Okay, I can't figure out how to create a datasocket in Visual Basic .Net 2008.  I can't figure out how to grab info from the Lookout OPC server.  I'm a little worried I may not figure this one out.
Message 4 of 11
(9,216 Views)
OPC .Net source code:
http://www.opcfoundation.org/DownloadFile.aspx/NET%20API/OPC%20.NET%20API%201.30%20Readme%203.00.htm?RI=315
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
Message 5 of 11
(9,211 Views)
Unfortunately, I'm not an OPC member.  I was trying to do this at low cost.  I keep running into the wall of the foundation.  Isn't there another way?
Message 6 of 11
(9,203 Views)
Another:  http://www.kepware.com/Products/KEPServerEX_VB_Install.asp
Message 7 of 11
(9,199 Views)
I'm checking that one out right now.  I'll let you know how it goes.  Thank you so much for taking your time to help me.
Message 8 of 11
(9,196 Views)
Ok, I have to admit, I don't know what to do with this.  I found this on my own yesterday.  It runs an OPC simulator and provides me with some old VB6 code that I can't get to work for me.  Really, I just need to get the code that connects to the National Instruments.LookoutOPCServer and then grabs the value of a single expression.  I've searched high and low and haven't found it.  I'm running out of time to get this project done and I'm thinking I may have to do something along the lines of writing to a csv file and reading in vb from that.  This is a let down because I was sure the Lookout OPC thing was a good tool.  Apparently it's a tool that takes too much effort to utilize.
Message 9 of 11
(9,191 Views)
I have had no real issues with the Lookout OPC.  You could also try the DDE method
Service: Lookout
Object: Process\Folder\Item
VB6 and VB.Net are slightly different, but is doable.
Message 10 of 11
(9,182 Views)
