Lookout
How do I send datamember points to an ".mdb" MS Access file?
Mike,
I'm attempting to insert a the date in mm/dd/yyyy format in the first column.  I've been told the TODAY() and NOW() will only provide a numerical value.  I think an option is inserting one text that includes 3 pots.  One pot for the month, one for the day, one for the year.  Between each pot use a /.  However I'm not sure what the proper syntax is when I enter it in the SQLExec object expression.    The pots will be assigned the system values (i.e PC date)
I appreciate your help
Thank you,
Hank
Message 11 of 19
(4,685 Views)
Here is what you need to get there:  http://zone.ni.com/devzone/cda/epd/p/id/1400
That is an example of splitting the month, day, year, hour, minute and seconds into seperate objects.
Also, Access date format is inserted between #.  #03/25/2009 13:34:54#
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
Message 12 of 19
(4,679 Views)
Mike,
I have got the SQLExec expression to work - no syntax errors.  I created MDB table and defined the fields in access.  However when I execute the expression it gives me an error on the Alarms Window in the ODBC area: [Not Buffered] 2300/-1053: [Microsoft][ODBC Microsoft Access Driver] Index or primary key cannnot contain Null value..
Hank
Message 13 of 19
(4,646 Views)
post your sql syntax, with values is fine.
Message 14 of 19
(4,644 Views)
Below is the sytnax used to send data to the table H13_Daily_Totals.  The corresponding fields'  datatype is a  number (field size=long integer)
The process name is "MAIN"
SQLExec expression: "INSERT INTO H13_DAILY_TOTALS (CHEM_TOTALS, WEIGHT_TOTALS, WATER_TOTALS, DEL_TOTALS, RATIO, TEMP_AVG, CONVEYOR_RUN, CONVEYOR_OFF, CONVEYOR_STOPS) VALUES ("&\\.\MAIN\DL1.H1_CHEM_TOTAL&", "&\\.\MAIN\DL1.H1_WEIGHT_TOTAL&", "&\\.\MAIN\DL1.H1_WATER_TOTAL&", "&\\.\MAIN\DL1.H1_DEL&", "&\\.\MAIN\DL1.H1_RATIO&", "&\\.\MAIN\DL1.H1_TEMP_AVERAGE&", "&\\.\MAIN\DL0.CONVEYOR_RUNTIME&", "&\\.\MAIN\DL0.CONVEYOR_OFFTIME&", "&\\.\HOUSE1\DL1.H1_CONV_STOPS&")"
Message 15 of 19
(4,642 Views)
What field is the primary key?
Id suggest a seperate column simply called  rowIndex as an autonumber
mike
Message Edited by Mike@DTSI on 03-30-2009 03:59 PM
Message 16 of 19
(4,639 Views)
When I originally created the table, I did not select a field as the primary key.  Does the field "RowIndex" need to be the first column? How does the autonumber data type function?
Message 17 of 19
(4,634 Views)
It can be any column over, first, middle, last.
Simply create a new column and set the field as an autonumber.  Then set as the primary key.
Mike
Message 18 of 19
(4,631 Views)
The error is gone, but no values were inserted in the fields.  Just "0"  I re-executed the command and did not create an extra row of values.
Message 19 of 19
(4,629 Views)
