Lookout
How do I setup user defined alarm setpoints?
I know how to setup alarms when creating a data member but I would like the user to have the option to change the alarm set points.  How do I create a data entry for the purpose of changing alarm setpoints?
(3,318 Views)
As you have probably already noticed the alarm conditions for data members can only be changed in edit mode.  Instead of the alarm in the data member, you could use an alarm object and 4 pots (or 4 textentrys, or 4 whatevers) for hihi, hi, lo, & lolo conditions.  If the pots are available to the user they can adjust the alarm levels in run mode.
(3,309 Views)
