Lookout
How do I specify different sample rates for 4 turbidimeters?
Avi,
Thanks, I'll give that a try. My other option, as someone suggested above, is to simply record the samples at the same rate for all four turbidimeters, and then set up a query to pull out the data I need. In the long run, that may be the simpler solution, but I am anxious to try your suggestion.
TTYL,
Allen
Message 11 of 12
(1,340 Views)
Hi Allen,
Sorry for the delayed response.  I looked at your process files briefly.  You are not using Modbus Object (sorry for bringing this up in my earlier post).  You are using a single ASCII object to poll all the 4 meters.  There's also provision to poll single meters, on demand.
When you're doing an Auto Poll, it appears, you really are polling each meter in succession (using the Poll2Address_Counter).
I am pretty sure the program can be modified to poll only 3 meters normally, and additionally the 4th one at regular intervals.  It'll just take some amount of time -- which I do not have much of these days, unfortunately.  I will not promise, but will try to look into this (as my Boxing day project eh? Smiley Happy )
Meanwhile, you will want to go ahead with whatever you had planned as the workaround.
-Khalid
PS:  "Bonjour.. Jetravail avec desordinateur.."  That's really all that I learned to say in French Smiley Very Happy
Message 12 of 12
(1,331 Views)
