I am using Lookout 4.5, build 12, and I am having a problem concerning pots. I have data tables created for the different size sewer stations my system monitors. For each station, there are setpoints for starting and stopping of the pumps. I want to be able to change the setpoints for a station on the client file using a pot and have it change on all other machines running Lookout. I did this in 3.8 using DDE, but I don't want to use DDE anymore.
I created a pot on the client file and URL'ed it to a pot on the server. On the server I created a table with a generic member "A" named "Lead Setp" and then created a member "A1" named
"C5_1LeadSetp" then a member "A2" named "C3_1LeadSetp" and so on....
In this table I connected the generic member "A" to the Pot I created on the server, and I connected A1 to its corresponding setpoint signal coming in from the field.
On the client file I connected (in the table similar to the one on the server but with all signals for the station) the "A1" member to the setpoint signal coming in from the field, and I connected the "A" member to the Pot I created on the client file which is URL'ed to the pot on the server file.
But, when I change the value of the pot on the client file, only the pot on the server and the "A" member in the table on the server change to the value of the pot on the client. The "A1" member whose screen I am changing the values from on the client does not change! This is the last thing I have to do and my file will be completely converted to 4.0. Does anyone have any ideas?
Thanks for any responses..
GBWY
Jason
Jason Phillips
