Lookout
How do I verify that the Citadel data tables Trace and Points are being updated?
I am using MSQuery to look at the data in my Citadel database, but it appears there is no data in the database. There are transactions in the A/E viewer. I am totally new to lookout and citidel. TIA.
(3,284 Views)
Hi Jeff,
Here are some old articles on accessing Citadel 4 data from MSQuery and MSAccess. These should at least give you a starting point:
http://zone.ni.com/devzone/conceptd.nsf/webmain/85CECF0AEEC5B1B28625680800733CC6
http://zone.ni.com/devzone/conceptd.nsf/webmain/0A3D4EEAC9208065862568080072DB9F
Also, do you have NI-MAX? You can check for data in there too.
Hope this helps,
Khalid
(3,280 Views)
Thanks. I already tried those two sites(step by step), still no luck. Thanks anyway. Also tried MAX, I am able to see data here, but no Trace or Point table data.
(3,264 Views)
