Lookout
How many items can a hypertrend group include?
I have a hypertrend group that I added 5 items to.  Only 3 are showing.  If I delete items and add them back in only the latest 3 trends show up.  Is this a limitation of hypertrend or am I missing something?
Message 1 of 8
(6,464 Views)
no this is not the limitation. we have used approximately 20 paramters in in one group.
Please make sure the data logging is enabled for all the parameters in the data memeber configuration.
Message 2 of 8
(6,450 Views)
Log to historical database is checked under the data member configuration for all 5 parameters.  Any thing else to check?
Message 3 of 8
(6,437 Views)
What version of Lookout is this?
Any Citadel errors in the alarms list?
Also, are they viewable in NiMAX?
Forshock - Consult.Develop.Solve.
Message 4 of 8
(6,431 Views)
Lookout Version 5.1
No Citadel errors in the alarms list.  Is there a way I can directly check the database to see if the data is in there?
They don't appear to be viewable in NiMAX, but I'm not familiar with NiMAX.  There doesn't to be anything at all under the historical data.
Any advice you can provide is much appreciated.  Thanks.
Message 5 of 8
(6,424 Views)
Nevermind.  I was able to delete and recreate the group and it seems to be working OK now.  Thanks.
Message 6 of 8
(6,422 Views)
Actually, this just moved the problem to whichever 2 items were the 1st 2 items in the 1st group.  I put dummy values in there as place holders as a workaround.  Seems to be working.
Message 7 of 8
(6,420 Views)
If this is a small process (test) I would be happy to test.
I have not had a similar issue in Lookout 5.1
Message 8 of 8
(6,408 Views)
