Lookout
How to display a set of samples
I am using the SAMPLE object to gather some samples, and the sampling is every 24 hours. Now what I cannot do is display the last 10 samples in a graph that moves on every 24 hours and shows the last 10 samples.
Help.
(3,538 Views)
You will have to log all the sample objects data members you want to trend to citadel. In the data member configuration enter each number (ie 1 for sample.1, 2 for sample.2, etc.) and click the "log to historical database" checkbox. You can also create an aliase (optional) such as Yesterday for sample.2. Each data member will be added to the "configured points" list as you save them. Now that the data members are being logged, you will see their trace in the hypertrend.
(3,535 Views)
Thanks. I never tought of Citadel.
(3,531 Views)
