Lookout
How to get custom graphics to work with the animator object
I Have a costom graphic that I wish to have change color depending the position of a Pot, and have tried using the animator object. However the animator object fails to change color when the pot is moved, when i replace the costom graphic with a standard one (a pipe) the color changes perfectly. The costom graphic is in wmf format so it should work. what am i doing wrong or is this just not possible?
(3,142 Views)
That's a little odd. Did you trying playing with the Gray Proximity settings? If it's not too difficult maybe you can create various colored versions of your graphic and use the Multistate object instead.
Is it possible to post the picture here so we can try?
Khalid
(3,142 Views)
