Lookout
How to run excel macros using lookout
I want use Excel macros for generating custom reports.Is it possible to run macros using run object in lookout
thanks
(3,131 Views)
I am pretty sure you can activate macros in Excel using the Run object in Lookout. I can think of two ways you can do this:
1. You can setup your Excel to run macros on startup using the Auto_Activate method. In this case, you will just launch excel with your workbook using the Run object and that should run the macros automatically. No brainer!
2. To better control as to when the macros are run we can assign in Excel some shortcut keys for their launching. We then would need to simulate these keystrokes to launch our macros. This can be done using the SendKeys method and some scripting, WHS Scripting for instance. See this pos
t for a scripting example which simulates Alt+Tab keys to bring-to-front an app.
You will launch the script from the Run object and this in turn launches Excel and then simulates the keys for luanching the appropriate macros. I admit this is kinda involved, but hey it works!
Hope this helps,
Khalid 🙂
(3,131 Views)
