Lookout
How to set range of ThumbWheels in LookOut Direct
Hi
I am using a pot object for my thumbwheel and it has a increment button and decrement button.
The range of my thumbwheel is from 0 - 9. If i press the increment button after 9 it does not do anything.
I would like to change it so that the range becomes 0 after 9.
For instance if we press the increment button after 9 it should go like 9,0,1,2,3....9,0 and
 for the decrement button after 0 it should be like 0,9,8,7,....0,9.. Can this be done with LookOut Direct?
I have tried using expression like
if(pot.value>9, 0, pot.value)  -------- for increment button, but its not working.
Can you me any suggestions to get over my problem please!!!
regards
Kone
(3,825 Views)
I don't think you can use expression to do that. Lookout doesn't allow a=a+1, or such kind of circular reference.
But I'm thinking if you can use Sequencer object to do it.
Ryan Shi
(3,815 Views)
Hi Kone,
Attached process implements this.  Please see the Pot connections to learn how it has been implemented.  Let me know if you have any questions.
-Khalid
(3,797 Views)
amazing
Ryan Shi
(3,793 Views)
