Lookout
Hypetrend
Hello, I am using the LOOKOUT version 6.0.2. I need to turn the Hypertrend "upside / down" in other word, I need to have zero point (0%) in the top and the 100% at bottom. Is that possible? Perhaps not in my, version but can a newer version do this?
(3,947 Views)
So, you wnat to invert the graphic representation of every pen....
Try this: Go to every item of the HiperTrend and set to 100 all Numerical minimum or Logical base position,  and then put a "-" sign in front of all Numerical maximum or Logical TRUE height.
That should do it.
(3,906 Views)
Accepted by topic author Krands
Hello, I think there's no direct button or configuration for turing Hypertrend upside down, but you can use mathematical method to solve the problem, for example you want to show the trend of pot1, and the range is from 0 to 100, you want to set the base to 100, and the top of graph to 0, you can use the Hypertrend to log 100-pot1.value, the trend may be the one you expect.
(3,866 Views)
