Lookout
I am trying to export a process (Lookout 4.5) to the web but keep getting the error "Can not find lookoutocx.dll in c:\nati
onal instruments\lookout". Even though when I use windows explorer I can plainly see the file in that directory. I have tried re-installing the software and that does not seem to help. Is there a step that I am missing. I never had this problem with 4.0.1.
(3,435 Views)
onal instruments\lookout". Even though when I use windows explorer I can plainly see the file in that directory. I have tried re-installing the software and that does not seem to help. Is there a step that I am missing. I never had this problem with 4.0.1.There have been many improvements to the process exporting features in Lookout 4.5.13 (build 13 on the Help >> About Lookout menu). In order to get this upgrade please contact National Instruments at 512-795-8248 and ask for Lookout technical support. They will need your product serial number in order to give you the upgrade.
Ian
(3,435 Views)
onal instruments\lookout". Even though when I use windows explorer I can plainly see the file in that directory. I have tried re-installing the software and that does not seem to help. Is there a step that I am missing. I never had this problem with 4.0.1.I would be willing to bet that the DLL you are trying to use uses other DLLs and that it is one of these other DLLs that are actually not found. If you an use the Microsoft Visual Studio dependency walker you can find out which of these is missing.
(3,435 Views)
onal instruments\lookout". Even though when I use windows explorer I can plainly see the file in that directory. I have tried re-installing the software and that does not seem to help. Is there a step that I am missing. I never had this problem with 4.0.1.Sukesh Puri
well i think that u are creating the web page but the paths u are giving in web export options are arbitrary..like u are export it to the local directory in the hark disk and in the server url u are giving the arbitrary path but not accessing it till now...to correct this option see the code of the u'r generated html page and see from where it is retrieving code just change the url to the local folder instead of server url given of required ddl..
(3,435 Views)
