Lookout
I am tryng to read the index datamenber of listbox activeX a always get 0
I need to change the cursor of one datatable. I try to use the listbox, but when i change the item and read the index datamember of the listbox it read 0 all time.
How can I get the real index value ?
(3,534 Views)
Can you please provide some more details -- I am not getting the entire picture.  We know how to change the cursor of a Lookout Datatable.  But why/how are you using a listbox?  And is this listbox an ActiveX control?
-Khalid
(3,530 Views)
The problem is that i am using a data table to make a recipe in a batch process, but i have a control panel to edit the data table and i have another control pane to select the recipe that i want to use. I would like to have two cursors, so when i select one item of the data table to edit, dont change the cursor that i have select to use like recipe for the process. Now when i select one item to edit, the cecipe change too, because it is the same cursor.
(3,527 Views)
You can have multiple cursors for the Datatable object -- up to 64.  Search the Online help for "multiple cursors," you will find a topic on that.
Let me know if I misunderstood your query.
Ciao!
-Khalid
(3,522 Views)
