Lookout
I 'd like to create a html page out of my process and acces it through my company intranet using inter
net explorer 6.Everything work fine except i can't do the transition of my html page process automatically in my browser(for example the page will move to another process for every 30 second).Has anyone have an idea or opinion about it. Thanks and regards.I 'd like to create a html page out of my process and acces it through my company intranet using internet explorer 6.Everything work fine except i can't do the transition of my html page process automatically in my browser(for example the page will move to another process for every 30 second).I'm using Lookout 4.01 (built 51) and i'm running win98 se.Has anyone have an idea or opinion about it. Thanks and regards.
(2,955 Views)
net explorer 6.Everything work fine except i can't do the transition of my html page process automatically in my browser(for example the page will move to another process for every 30 second).Has anyone have an idea or opinion about it. Thanks and regards.Rudin,
You have two options here:
1)you can create one process with three panels and use the activate, maximize, minimize linked to a timer object in Lookout.
2)the easiest way would be probably be to create three different process files for the three panels and export them to three different URLs. After that you could modify the HTML scripting of the page. We do not support that since it is not Lookout support but HTML support. However I think there is an HTML macro which is called "metaRefresh' macro that should do the trick. Here's an external web page that I found talking about that: http://www.baylys.com:8080/help/manilafixer/manilaextras/metarefresh
You can run a search on search engine for the metarefresh command and find relevant info about it. This is
the command used when you reached a website which page has moved and that says"click here if you want to be redirected now, or you'll be redirected automatically in X seconds". You could probably find a page like that to see how the scripting is done. I hope that helps.
Cyril Bouton
Cyril Bouton
Active LabVIEW Developper
(2,955 Views)
