Lookout
I'm getting a windows error stating that virtual memory is low with Hypertrend .
When accessing my hypertrend object I'm getting a windows error stating that windows is running out of virtual memory. Then the PC crashes. I was told by NI about a year ago when I had the same problem..that I need to upgrade from build 9 to build 18. That fixed the problem but about a year later the problem has happened again...Any help or ideas with this problem??
(3,693 Views)
Here's the link to the latest update which is 4.5.1 build 19.
ftp://ftp.ni.com/support/lookout/fixes/4.5.1/
This should take care of the problem.
Remzi A.
(3,693 Views)
Great...Now how do I install this patch??
(3,693 Views)
You need to unzip lo451_fixes and copy all the files inside the Lookout folder.
Remzi A.
(3,693 Views)
Thanks....are all of the fixes required to correct the problem I asked about originally. I don't what to create new problems. (Why fix what's working).
(3,693 Views)
