Lookout
I need to know if I can manage to control with lookout drivers some Ethernet instruments, those instruments communicate with an HUB interface with TCP/IP protocol
Before we use the normal field point interface, but know those instrument are not made anymore with currents and voltages signals, they work with Ethernet protocol..
(3,367 Views)
Assuming your Ethernet instruments use simple ASCII commands, you can try using the IPASCII Object in Lookout.
With the IPASCII Object, you can communicate with any device that transmits and accepts formatted strings of ASCII data via the TCP/IP, UDP, or IP protocol. See the Online help for more details.
Rgds,
Khalid
(3,367 Views)
