Lookout
I need to transfer data from Citadel DB to OSI Pi?Any simpler way other than OPC?
We USE Lookout,Citadel and OSI Pi Server over a network.
(3,099 Views)
Citadel comes with a ODBC driver. This driver can be used with other applications to read Citadel historical data into your application. Since I am not really familiar with OSI Pi, you might figure out if OSI Pi is an ODBC client and if you can send SQL queries from it to retrieve Citadel data.
A good starting point is followinig link: Accessing Citadel Data from Other Software
Hope this helps (a little bit)
Roland
(3,099 Views)
