Lookout
I only have USB on my computer and USB to program my PLC how do I set look out up
I recently upgraded my computer and it only has USB ports but no serial ports.  I know have a USB cable to program my Mitsubishi FX PLC.  Is there a way to use lookout and instead of using hardwired COM ports to monitor the PLC.  I have lookout 6.0.
(5,977 Views)
USB to Serial
http://www.bb-elec.com/product_family.asp?FamilyId=397&Trail=45&TrailType=Main
Our internal cards
http://www.bb-elec.com/productsubcat.asp?MainCategoryId=6&Trail=2&TrailType=Top
Good luck,
Mike
Forshock - Consult.Develop.Solve.
(5,974 Views)
That really would not help me.  I have USB connection to the PLC I have a USB port on my computer.  The PLC software uses USB no problem.  Lookout uses Serial COM ports.  I would like to Use Lookout on this setup to comunicate to the PLC from the computer using only USB is it possible. Or do I have to use old cables to connect to new things.  In the past I used serial cables and the solution you gave me just fine but the newer products are getting away from serial cables and using only USB.
(5,969 Views)
