Lookout
I want to create a Modbus Slave to communicate with a DCS (Modbus Master) on TCP
I am looking to setup lookout so that I can Poll one computer for information from a DCS acting as the Modbus Master. I need to do this over an ethernet network, not serially. Is this possible? If so, how do I go about it?
(6,789 Views)
You have a few options, depending on the controller.
Modbus TCP Slave, simplest ive used.
Good luck
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(6,788 Views)
Thanks for the response.
I think I probably should have been a bit more specific. I'm looking to do this using Lookout. I am aware of the Modbus and ModbusSlave Objects, but is there a way to set them up to have my system be a slave on a TCP/IP network? I have read some places that say it can't be done, while others say it can be.
Can Modbus TCP Slave be used with Lookout? As an OPC object? I'm pretty confused here.
Andy
Message Edited by acb310 on 04-09-2008 04:10 PM
(6,785 Views)
Yes, you can.
The Ethernet option was added in 2004, so maybe you see some threads before 2004 saying that it is not supported.
What's your lookout version?
Ryan Shi
(6,776 Views)
