Lookout
I16 format in plc becomes U16 in Lookout
I have a plc which stores words as I16 (integer
16 bits) so range is -32768 to +32767. However,
when read by Lookout using Modbus serial, words
are displayed normal for the range 0 to 32767,
but for the range -32768 to -1 Lookout displays
32768 to 65535. It seems to me, that Lookout
does the transform from I16 to U16 (unsigned 16
bits).
Do anyone have a solution?
Andres Thorarinsson
Vista Engineering, Iceland
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,145 Views)
Andres,
Have you tried using the datamembers S40001 through S49999? These return
values as signed integers rather than unsigned.
Dave P.
Lookout R&D
andresvista@my-deja.com wrote in message <7ro51r$b7n$1@nnrp1.deja.com>...
>Hi,
>bits).
>Andres Thorarinsson
(5,145 Views)
