Lookout
Installation fail message appears at end of Lookout installation
At the end of Lookout 5.1 installation, a message appears in the pop-up that installation failed. However, when I run Lookout and my application, everything appears OK. This was with XP. I have never had the problem before on NT or 2000. However, I tried it on 95 and had the problem and Lookout would not run -- some components did not install.
(3,089 Views)
About Lookout 5.1 in a Win 95 that is ok because it is not supported. The minimum OS needed is Win 98.
Now about the error in XP this is a known issue. It does not affect the performance of Lookout so you don’t have to worry about it. Our developers are working on a fix for it.
If you have any problems with Lookout let us know.
Thank you.
Ricardo S.
National Instruments.
(3,083 Views)
