Lookout
Installing LK45_web.exe
After exporting a web page to a web server, the pages run correctly IF the client system has Lookout installed. If Lookout is not installed, I need additional software. The pages contain a link to ftp the file LK45_web.exe from National Instruments.
First,the link is bad or expired.
Second, I found the file and downloaded it, but can't do anything with it. It is not a windows file. The accompanying text file implies an installer is reguired.
How do I get this to run?
Bob L
(3,463 Views)
Hi Bob,
I was able to download the lk45_web.exe from the following FTP site:
ftp://ftp.ni.com/support/lookout/webclient/4.5/
Then, I just ran it which in turn launched the installer. May be the file got corrupted when you downloaded and want to try again.
Thought this info' would be useful...
Khalid 🙂
(3,463 Views)
Khalid,
Yes, bad download. I actually had downloaded it 5 different times, on 3 different systems, through 3 different ISP's, under both NT4.0 and ME. All failed using IE5. (File was corrupted without error indication)
With WS_FTP it downloaded correctly the first time.
I suspect it's an IE5 issue that I need to investigate. I'll post my findings when I get a chance to research this.
Bob L.
(3,463 Views)
