Lookout
Internal Error(2)
En el alarm windows uno de mis procesos me manda el siguiente error: " Internal Error(2): Processing read data (50): Can´t convert data to lookout format (00000004)"
De que se trata este error?
Cual es la posible solucion?
(6,948 Views)
There is a column called "object name" in Alarm Window. What's the object of this alarm?
Ryan Shi
(6,933 Views)
I am having the same alarm as well. It is associated with my OPC client (Kepware Kepserverv5 in this case). Any thoughts?
(6,581 Views)
It's probably because you are reading or writing an unsupported data type. Do you have array data item in Kepware OPC Server?
Message Edited by Ryan.S on 03-07-2010 08:14 PM
Ryan Shi
(6,567 Views)
