Lookout
Is it possible to convert a process file from 6.2 to 6.1?
I've tried to compile the lks file in 6.1 but can't and get error messages.  Does anyone know if this is possible or how to do so?
(6,104 Views)
Accepted by topic author DST1
You cannot compile 6.2 lks file in 6.1, because there are some additional information in the lks file which cannot be reconganized by 6.1.
An option is to manually edit the 6.2 lks file to match the 6.1 style. You need to get a 6.1 lks file as example. The header (first 20 lines) in lks file may be different.
Ryan Shi
(6,092 Views)
