10-02-2002 06:15 PM
10-03-2002
10:30 AM
- last edited on
11-11-2025
09:15 AM
by
Content Cleaner
Do you have the Datalogging and Supervisory Control (DSC) Module in addition to your LabVIEW Professional? If yes, then please write back as the approach is different (and easier).
Assuming you only have LabVIEW Professional (and not DSC module), to connect to the Modbus device using Lookout OPC Server, please see the following tutorial:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2C7CAI&l=en-US
You must know that if you have lot of I/O points, the above approach of using just LabVIEW (without the DSC module) becomes cumbersome and degrades the performance as well. For more I/O points, and for features li
ke Alarms, Historical data, Events, Security, you will want to use the DSC Module.
Hope this helps. Please write back if you have any questions.
Khalid
10-04-2002 06:14 AM
10-04-2002 08:43 AM
