Lookout
Is there a problem with Allen Bradley PLC and web server export options
It says this object will not run in a client version. I have a development version and a client version. Maybe I'm not understanding the error message. Lookout 5.0
(3,302 Views)
The process you upload to a web server needs to be a poor client process. It means you have to create a client process without the PLC driver and a server process with the PLC driver. You will just upload the client process and the server process will stay on the Lookout Server machine.
There are several links on the support site those explain the prefered client-server architecture to choose for a Lookout application.
Building a Sample Server-Client System in Lookout
Converting a Lookout Server Process Into a Client
://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/4c13547ceb6354a886256b80...
Hope this is a good starting point for your Lookout application design.
Roland
(3,302 Views)
Thanks for your information it was very helpful.
pizzoc
(3,301 Views)
