Lookout
Is there a way to pause the sequencer in lookout and restart it where it left off in the step?
I am wanting to be able to pause the sequencer and have the ability to restart it at the point it was paused. I ahve been able to pause it, but it resums at the start of the step.
(3,149 Views)
Have you tried using the Goto datamember -- you can force the sequence to a particular step with this.
Please give more details of what you're trying to accomplish and what you've done so far so we may help you better.
Khalid
(3,149 Views)
You could use expressions for the time limit, jump, and goto datamembers. That way, when the pause switch is true, they will be set to a very high number (time limit) or false (jump, goto). When the pause is false, the datamembers would be set to their normal values.
Michael Shasteen
Applications Engineering
www.ni.com/ask
1-866-ASK-MY-NI
(3,149 Views)
