Lookout
Issue attaching mulitple ascii strings to mulitple PB's
I have 10 pushbuttons. I want to attach a different ascii command to each pushbutton to be sent out to my Unison Lighting Controller. Right now, I can send out 1 command to my device and get a response back. My issue is i need to send out a different command per the other pushbuttons. can anyone give me a step by step on how to do that? I'm using lookout 6.0.2
thanks for the help
Haj
Message Edited by Haj on 05-07-2008 10:11 AM
(5,850 Views)
Have a look at this process. It uses a radio button to switch the requestformat and RQV.
In this example, all formats and RQV data are directly input in the connections.
You can create textentry or pots on panel connected to those ASCII datamembers instead, so that you can modify the commands. And then, use the Radio Button to switch.
Message Edited by Ryan.S on 05-08-2008 04:52 AM
Message Edited by Ryan.S on 05-08-2008 04:56 AM
Ryan Shi
(5,834 Views)
