Lookout
L3 Pushbutton Conversion from 3.8 to 4.0
I have converted an older 3.8 version program to 4.0 and I need to add an
additional L3pushutton to match the existing one. I copied a existing pushbutton
(cntrl-drag) and redefined it, and also edited the ascii file with no luck.
I push the button and nothing happens (PLC5 via KTX)
(2,966 Views)
In version 4.x you can use Latch Output verify the output was updated. further documentation is in the help files.
(2,966 Views)
