Lookout
Loader object question
I have an experiment setup that has a bunch of common equipment and a
chamber that supports 3 different experiment rigs. I created a Lookout
4.0.1 process for the common equipment and a separate process for each
experiment rig, (e.g., Common_Process, A_Process, B_Process,
C_Process). Only two processes need to be loaded and running
simulatneously (the common process and a specific experiment's process).
The common process is always loaded. I created a radio button selection
list to allow the operator to choose loading Experiment A, B, C or
None. I then created a loader object for each experiment. Here is my
annoyance. For Experiment A, the Loader object loads the process when
the radiobutton for Experiment A is selected (no prob
lems here). But
the trigger for unloading is when any of the other 3 radio buttons are
selected. The result is whenever we change experiments, I get a 2 error
messages. Process:Common_Process, Area:Comm, Description:"Unload:
Process not found: X_Process" where X is the name of the other
processes. Is there a better way to trigger an unload such that it will
not try to also unload the other processes?
Please remove the DELETE from my address and respond both directly to me
and to this NI usegroup.
TIA,
Alan
Historical, though non-PC, quote of the day:
"We have staked the whole future of America's civilization,
not upon the power of government, far from it.
We have staked the future of all our political institutions
...upon the capacity of each and all of us to govern ourselves
according to the Ten Commandments of God." - James Madison
(3,444 Views)
FYI - here is the response I got directly mailed to me from NI Support.
The solution works great. - Alan
Date: Tue, 25 Jul 2000 14:41:53 -0500
Subject: Re: Loader object - Unloading Logic Problem
Alan,
I have found a solution to your problem that you are receiving when you try
to
unload a process that has not been previously loaded. If you place the
following code in the unload portion of the Loader object (modifying it
accordingly) will eliminate the errors you were seeing.
if(Loader2.Load,if(!Radio1.2,1,0),0)
The code above checks to see if the process has been loaded by checking the
load
attribute of the Loader object. If the process has been loaded, then we
check
to see if we have selected a different process to load, if we have checked a
different process, then we tell the load object to unload the process.
Hope the above helps you in your development of your application.
Best Regards,
John Meier
http://www.ni.com/support
> the radiobutton for Experiment A is selected (no problems here). But
> TIA,
> Alan
....upon the capacity of each and all of us to govern ourselves
(3,444 Views)
