Lookout
Logon using touch screen only
Does anyone know how to get access to the logon (Ctrl + L) from a
pushbutton or other object? When the operator has on gloves, it is very
hard to hit the little window in the lower left. The operators only use
their employee ID #, so is there a way to call up the keypad rather than
the keyboard for name entry. Can either the keyboard or keypad be
called up from a pushbutton or other object? Even changing the size
of these objects would help.
(4,002 Views)
Currently there is no option to do this in Lookout. This has been asked for in the past. If any additional people would like this functionality added, please post a responce to this question with your name and company info. Increased demand affects developement.
(4,002 Views)
I have the identical issue.  I will post this as a new item since the original posting is 7 years old.
(3,752 Views)
