Home
Community
Discussion Forums
Special Interest Boards
Lookout
Topic
Lookout
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Lookout 3.8 Ascii Obj not dialing
Robert Phillips
Member
05-09-2000
07:33 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
When setting comx to "Hardwired", is there a way to use Ascii Object to dial
a modem by sending "ATDT1234567"?
The PCL driver I have does not have "OFFHOOK" property so it always hangs
up after first poll.
0
Kudos
Message
1
of 2
(4,327 Views)
Reply
Re: Lookout 3.8 Ascii Obj not dialing
Kermitthefrog
Member
07-23-2002
09:33 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
This KB,
How Can I Use the ASCII Object in Lookout to Send Data to the Serial Port?
talks about sending strings through the ASCII object. This should help you figure out how to send your dialing command.
1
Kudo
Message
2
of 2
(4,327 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
